are the arizona speed and marine headers any good?
I have them and love them. They have 2 problems the coating is not so good and bolt clearance very bad.I LOVE COBRA'S -
THEY TASTE LIKE CHICKEN!
95 SS clone- LT1, t-56, pro 5.0, short stick, sidewinder knob, AS&M headers, 3.73 , TA cover, Borla exhaust, MSD , BMR- chromoly suspension, Torq Thrust II
the bolt clearance next to the primarys that bolt to the head? were at in pa are you?Originally posted by HottestZ28I have them and love them. They have 2 problems the coating is not so good and bolt clearance very bad.1996 Trans Am WS6
A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
I like all the AS&M stuff. Great quality and excellent customer service(at least for me
), and there coating issues and jig alignments are constantly being worked on.
The AS&M mid-lengths are a great street/strip header and will give you plenty of ground clearance.
I have the RK's which are nearly the same. Both are difficult to install and bolt clearance and plug access is bad. You will most likely encounter fitment issues which require some creativity.
They perform great and they are the next best thing to LT's since they have the 1.75 primaries. Very happy with them.1995 Z28 Convertible, 350ci LT1 73K miles M6.
How about the edelbrock shorty headers for the F-body ls1? Are they any good? They come in several different coatings one being ceramic since I hear thats the best one.http://www.cardomain.com/ride/2317021/1
2001 Blk Firbird Formula 6 sp hurst shift (my toy) Upgrades: American thunder Flowmasters, Cross drilled rotors, Centerforce Clutch and Flywheel. Car is in Bodyshop for full painting now with Ram Air, Rims, and wing being installed.
2006 Blk Cobalt SS (my commuter car)
2003 Harley 1200 sportster 100th anniversary (For sale)
2007 Jeep compass
Had them on my 94 (RIP)and I liked them alot. If I had to do it over I would do Long tubes.Kbddsfc,B&M Ripper,Ws6 Rims,Hotchkiss Stb,Bmr Lca,Gwphr,Strange 4:10's,LPEds,Borla,AS&M Headers,RT cat,Powerslot rotors,Hawk Pads R/Pf pads Fr,Mba shift knob,Slp Hood&Airbox,Holley Powershot filter,Fernco mod, Lt4km,Firebat decals,T/A Girdle,HPP.160stat,Bilstein shocks,Z06 Brakes,AFS ZR1's,GSD3's.
I bought a set of the AS&M's used ($175
) and they are great headers. Never found the bolts or the plugs to be a serious problem. The HPC coating that came on them is finally starting to deteriorate (the headers are 8 years old), with some small dots of rust on the weld spatter at the main flange. Even where the coated headers were drilled and welded for an EGT bung, there is minimal deterioration of the coating. And these headers have been exposed to some serious levels of boost and nitrous.
I got them after a buddy of mine dyno'd around 800HP, and found the AS&M's made more peak HP than the Hooker LT's. It was only when he pushed it above the 800HP level that he was able to get better performance out of another brand. That's when I got his AS&M's "cheap".
Montgomery county. Yeah 2 header bolts had to be cut and totally forgot to antisieze drivers front primary putting them in. Wish i could have had them without AIR tubesOriginally posted by redws6the bolt clearance next to the primarys that bolt to the head? were at in pa are you?I LOVE COBRA'S -
im afraid of breakin off a header bolt in the head....im in montgomery county as well. which part are you from?Originally posted by HottestZ28Montgomery county. Yeah 2 header bolts had to be cut and totally forgot to antisieze drivers front primary putting them in. Wish i could have had them without AIR tubes1996 Trans Am WS6
