And failed, I need to do a rotors and pads on all four and inner tierods on both sides. Anyone got any tips/tricks I've done a couple brake jobs never on a f-body, and have never done inner tierods.
Took the bird for inspection......
Brakes are a piece of cake (or pie, whatever you like lol
). Never touched the tie-rod ends before though
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Thats pretty scary. All four corners were bad enough to fail inspection? How long have you been driving with bad brakes? I dont like to preach, but brakes are so important. You should never let them get that bad. And both tierods? How much play do you have in the steering wheel? It must feel like you are driving a truck.
Like Steve said, brakes are cake. If you have done them before on another car, you will be fine. There arent too many differences in disc brakes.No F-Body right now
brakes are gonna be easy, make sure u get good parts(i like O.E.M from levines or raybestes(sp?)) as for inner tie rods, they are easy if u have the correct tools. but dont forget to get a alignment done afterwards. a tip to tie rods is to count how many turns it takes to get the old one off, that way if the new one is same size or close u can get the spec back in as close as possible2009 Honda Civic EX- the daily beater
Pretty straight forward, nuts and bolts stuff. The inner tie rods will require an alignment afterward (or you need to count threads on the rod ends to ensure that it is at least close). TO break the tie rod joint loose, either pound it out with a hammer (because you are replacing it anyways) or use a pickle fork. The brakes are pretty straight forward.Originally posted by gimp19And failed, I need to do a rotors and pads on all four and inner tierods on both sides. Anyone got any tips/tricks I've done a couple brake jobs never on a f-body, and have never done inner tierods.
Be aware though, in order to fail NYSI for brakes they need to be just about metal to metal (I find it ahrd to beleive your driving on metal to metal at all four corners). Otherwise, all they can do is ADVISE you to replace them soon. Also, check the play in the tie rods yourself. Many (dishonest) shops fail tie rod ends for a little side to side play. Really, its up to the discretion of the tech, but they arent really unsafe until you have some up and down play at the joint. It sounds like a Monroe muffler or Pep Boys state inspection.
Im not saying that they didnt treat you right. You may indeed need all of those parts, but this is one of my pet peeves. Goober technician (who make us all look bad) who fail cars dishonestly to make an extra buck.
THree letters will usually set them stright D....M......V! Many shops dread a report to the department of motor vehicles. They are the governing body behind liscensing shops to do NYSI's and they are just looking to take away liscenses!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Id defiantely check that out first with another shop as well and see what they say, for all four brakes to be bad enough to fail seems a little suspicious, though it is possible i suppose. Go get it checked out elsewhere, the shop i usually take my car too always says things like, within the next year or so you should consider doing this.... and they always seem to be right on the money, but never charge me to do anything that doesnt need to be done.-Dan
He did say the brakes "could pass" but the rotors are pretty shady the car still stops all right. There is quite alot of play in my front wheels drivers side moves quite abit, i didnt notice it unless I was stopping the car would pull to the left, wasnt't sure why thogh. I've been putting the brakes off untill the weather warms up.
1994 Firebird Formula 138,000 Completly Stock
1995 Caprice 9c1 61,000
2001 Intrigue GL
The brakes are real easy... You shouldn't have any problems. As for the inner tie rod ends go to the auto parts store and rent the correct tools. Also math up the end for lenght and count the number of turns to get the alignment close. When you done get it aligned. Good luck...2005 GTO (mine) K&N CAI and Magnaflow exhaust, drilled and slotted rotors, and other minor mods.
2002 V6 Firebird (wifes)
2013 GMC Sierra (mine)
2011 Cadillac CTS4 (wifes)
i hope he doesnt look at a 2000 and newer 1500 or S10, those rotors rust out within 20KOriginally posted by gimp19He did say the brakes "could pass" but the rotors are pretty shady.2009 Honda Civic EX- the daily beater
Oh Sorry. I forgot about private inspection stations. I live in Jersey where we have free state-run inspection stations. They arent trying to sell you anything, so they dont tell you stuff is broken that isnt. It sounds very possible that they are exaggerating or lying about the condition of your parts to make a sale. Like others have said. Get a 2nd opnion... Or check them yourself.No F-Body right now
Explain to them too that youll do all of the work yourself and then bring it back to them, maybe it will change their opinion on the necessity of this venture.-Dan
I'm not sure this is the correct one, but it's similar...Originally posted by gimp19What tools do I need, do I need to take the outer tierod out of the socket to replace the inner one?
http://cgi.ebay.com/ACDelco-INNER-TI...ayphotohosting2005 GTO (mine) K&N CAI and Magnaflow exhaust, drilled and slotted rotors, and other minor mods.
