That thing stuck in the middle of the piston is an exhaust valve...
I hate when this happens...>>>
No, I should have made an explanation. One of the techs at work had to run 16 engines enclosed in a steel box ungoverned at WOT for 1 hr. or until they exploded. You could tell when they were going to blow up because there was an unmistakable death wail. Almost more fun than anybody should be allowed to have at work.
I could probably blow up some engines too if you need any help.
Andy'94 Formula M6, XE224/230 w/1.6 RR's, hardened pushrods, Comp R lifters, SLP ceramic coated shorties, Random Tech cat., Flowmaster cat-back, CSI water pump, vented opti, PCM tuning by Spraytheway, BMR k-member, SFC's, DSL, LCA's & brackets, adj. PHR
339 RWHP, 341 RWTQ
'00 S-10 ZR2
