MadZ28 tune, and 160F T-Stat. are all in. Is the car suppose to sound a lot quieter at idle then the stock tune? My car was, so quiet I'm concerned if its normal, or something is wrong. Is this because of the leaning of the gas, and am this wont hurt the engine in anyway? How much more mileage should I get on a tank of gas now? Thermostat installation didn't go smooth had air pockets finally got it all out took a long time.
My rubber elbow air duct got a couple of rips on it where the metal fastener goes around, but its not ripped in the portion where air can get through. (Happened today when I used screwdriver to get it around the fitting. Its not very strong.) Should I replace this? If, so is there a good performance1, or is it just as good as the stock 1.
Did I cause any damage when I turned the car on with the air duct was off, and sensor WAS disconnected because the car started then shut off. So I decided that wasnt smart, so I put the duct back on then started the car, and it started with no problem.
