hey guys, I just got finished doing a LE2 head and cam package, as well as building-up the bottom end of my motor. I was just wondering how long the typical break-in period should be for the lower end and valvetrain untill I can give her full throttle. Its a tough call between getting it dynoed right away and tuned right OR babying it around for a while with the tuning way off. Anyone have any helpful advice??
break-in period??
break-in period??
1997 Camaro Z28 w/ LT1. SRP forged pistons, Eagle H-Beam forged Rods, 9.2:1 comp ratio. Voretch S-trim supercharger w/ 6 lbs. boost. 36 lb. injecters, T-Rex in-line fuel pump 3:73 gears, Auto w/ Hughes 3,000 stall, transgo shift-kit, LE2 heads + custom cam, 52 mm. tb, Comp. 1.6 rr. + chromemoly pushrods, pacesetter LT's, no cats, Y-pipe, SLP loudmouth cat-back, SLP sub-frame connectors, MSD wires, HI-6R ignition, I think thats it.....
Tags: None
Get it dyno'ed right away. In the past the break in period was largely due to the flat tappet lifters. Roller motors do not have a need to break in the lifter/camshaft lobe mating surfaces. The rotating assembly and piston rings also need to experience a significant load and a widely varying RPM range to seat the rings to the cylinder wall properly.
Get it on the dyno and put the hammer down and get that bad boy tuned.
