hello there i have a 89 gta w the l98 motor in it. almost everytime i start the car is idles weird then just dies it does it abotu 3 or 4 times befor it stays running. what makes it weird is when it is idling funny if i give it gas it wont rev up or anything it is like teh gas peddel isnt doing anything the car ran fine it was sitting for 3 years but i just had the mas airflow sensor changed and abotu 3 days later i was having these problems any advise on what i should do. there is no check engine light.
weird starting problem any advise
Check the burn-off relay for the Mass Air Flow sensor. If that relay has failed, it will result in the exact symptoms you describe. Whatever it is, it definitley sounds to be MAF related.Tracy
I know that on an LT1, if you unplug the MAF senor the PCM will default to speed density mode. This is how we LT1 owners quickly diagnose MAF problems, we just unplug it and see if it runs better. I'm not sure if your L98 ECM will default to speed density in the same way, but it is worth a shot.
Did you try replacing the burn-off relay?
I had an 88 5.7 Iroc that was a chronic problem for years. It would barely start, then run like absolute crap and nearly die. I'd have to shut it off and wait a few minutes then try again. Sometimes I had to re-start it half a dozen times to get it to run right, then it would be fine until I shut it off again.
I replaced the MAF burn-off relay and it never gave me a problem again. The relay is responsible for the cleaning cycle the MAF goes through. The mechanic that finally fixed it told me that it heats up the MAF filament red hot to burn off any contaminates and clean it. If the relay is bad, the MAF will never clean itself and it will produce bad readings.Tracy
Have you replaced the burn off relay?
It is very possible the MAF sensor is OK and the burn off relay is shot. Relays are cheap, replace the relay first.Tracy
There is no MAP sensor on MAF thirds gens. It just defaults to standard tables.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
