Well i just got a new intake elbow to replace my ripped one. Only thing is I don't see a hole so i can put in the tube that i assume is the vent for the opti. Do i need to drill one or can i just let it vent to the air?
Intake elbow ?
Yup, drill a small hole and poke it in.Tracy
If its the 1LE elbow, the hole would have been there if you had ordered the right one.... they make one without the hole for 93-94 models, and one with the hole for 95-97 models. Same with the standard LT1 elbow, with the air silencer pipe - 2 different part #'s.
Shoebox's website really is the Bible for LT1 parts and tech information. It has the info on the 2 different 1LE elbows. If you aren't using his website as a frequent reference, you are short-changing yourself.
http://shbox.com/1/4th_gen_tech1.html
1993-1994 1LE intake elbow
(no vent hole for opti) 25147210 $44.98
1995-1997 1LE intake elbow
(for vented opti) 25147187 $43.82Fred
Originally posted by InjuneerIf its the 1LE elbow, the hole would have been there if you had ordered the right one.... they make one without the hole for 93-94 models, and one with the hole for 95-97 models. Same with the standard LT1 elbow, with the air silencer pipe - 2 different part #'s.
http://shbox.com/1/4th_gen_tech1.html2006 Saturn Ion Redline
2003 Mits. Eclipse Spyder
Originally posted by ryan34its a trick flow, it said 93-97. I'm guessing it didn't put one there for the 93 and 94 guys.Steve
87 GN - its just a 6... Mods
Originally posted by ryan34its a trick flow, it said 93-97. I'm guessing it didn't put one there for the 93 and 94 guys.Fred
