I could get it going in a couple days, but I want to sort a few things out to make it easier to work on in the future and might have to order a few oil fittings, make some new ignition wires, and change some of the wiring harness, etc, so I will probably drag it out a bit. I'm just glad to have the engine back in there - That was definitely the hard part - The rest of the stuff I have to do - I've been there before.
One thing I'm NOT looking forward to is retorqing the heads after run-in. That means pulling the headers out of the way to get to the last row of head studs and that will be a pain.
Thanks Kev, I'm at 8.9 or so. I still have the original blower which probably won't make a lot of boost with the bigger engine, but I'll get a T-Trim when I get over the buyer's remorse for the engine parts. It's hard to say what the boost will be with the different cam, larger engine, and more ported out heads. If I can get it up to 8 or so, that will be OK for starters, but I would def get bored with that before too long. I'll see how it tunes up and how well the meth injection works now that I don't have broken pistins in there fouling everything up and go from there.
Just curious...why would you have to retorque the head bolts after run in? Is this normal for a new motor?
I thought the bolts were "make till break" or something to that effect, meaning the are torqued once, stretch, and left alone.
Depends on the head gaskets and bolts used. I have Cometic Stainless MLS head gaskets and ARP studs. Once the assembly is heat cycled, it won't have the same torque when it cools, so you loosen the nuts a quarter turn & retorque them, then you're good to go. Just like you should do with header bolts a couple times, then they stay put.
It is a common procedure. Even when you use the 3 step torque process, it's still a very good idea to retorque the nut on the head studs after a heat cycle.
Your going to run Alcohal? With all of that stuff alone, depending on how much u port the heads you could be up at like 700hp easy, especially running methanol. I dont know how you would get bored of that.
Ported fast 92 mm intake and 92 mm TB on order. 11.539 @ 118.82 1.649 60 foot.
It will depend if he is going to run denatured ethanol or methanol, but generally speaking the real benefits from running alky injection is not from a direct power increase.
Alky injection is very important on a boosted car with no intercooler. It keeps the induction charge temp down, allows you to lean the gasoline a/f target ratio, and it allows you to run more timing and boost because of this; all the while helping to prevent detonation and detonation induced pre-ignition(not good).
Alky or alky/water injection substantially increases the effective octane in the combustion chamber. So just the addition of alky alone will likely not show any gains in power just by itself. When you first install alky injection, normally the measured a/f will go pig rich. You compensate by pulling fuel from the the gasoline map. But the neat thing about alky injection is that you can run slightly leaner than you would normally be able to without the alky injection. This has the potential to make more power as well. So the combination of being able to run more timing, keeping the induction charge temp down as much as 100 deg F, helping to avoid detonation, and running a bit leaner all work together to make more and safer power.
Alky injection can be tricky to tune and/or map, but it is a huge plus on N20 and forced induction cars.
Kevin, if you DO get bored with all that power, you could always install some (small amounts ) Nitrous...
Greg W. in West Michigan 1992 Formula WS6-A/R Rims, Stock L05 swap, Former Abuse Victim 1983 Z28-Parts car- *Sold* 1984 Z28-305 HO Auto *Sold* 1986 Camaro-V-6 5Spd *Sold* 1984 Camaro-V-6 Auto *Sold* <Motor out
