I am hearing a squeeking noise comming from the passenger front tire. It makes the noise when the car is rolling, it does it forward as well as reverse. It also does it when we push down on the front end. I would highly think it is something to do with the front suspension but i havent had a chance to check. What would you guys think the problem is, I would like to fix it so I can start to drive the Z again.
Squeking noise
bad shock maybe. only one way to find out, get under there and look.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
