Joe 1320 wrote a while back about replacing all the seals at the timing cover while the Optispark is being replaced.
Please take this advice seriously!
My latest Opti failure (only got 36-37k on this one) was directly due to a leak at the opti drive shaft seal. Oil penetrated the cap and rotor side and blackened the end of the rotor. Additionally, and the primary reason for the car not running, was where oil contaminated the entire length of the rotor and left carbon tracks where it was arcing to the oil streak on the cap.
Now the question: Any advice how to change all these seals w/o the benefit of the half a dozen seal pullers and installers listed in the service manual? Do any absolutely NEED the special tool?
Thanks Joe!
Heres the numbers again from Joe's post
10317886 water pump drive seal $3.98
12552428 opti drive seal $3.88
12553792 o ring for water pump shaft (need 2) .70
12554314 front crank seal $14.50
Sean
Thanks Joe!
Sean
