i just changed both the accesesory belt and the A/C belt on my 98 z28. The squeeking went away for the most part, but it's still there a little bit. And the degree of squeek seems to be pretty random, except that it always increase with the RPM's. Maybe some belt dressing on the new durlast belts would do the trick? any ideas?
belt noise
Save the belt dressing. That stuff was mainly designed as a band-aid fix for the old v-belts.
Try pulling off the belt and thoroughly cleaning all the pulley belt surfaces with a solvent or some brake cleaner. This usually helps. Also spray some type of lubricant on the tensioner spring.
I'll second that. I used belt dressing once. It works for a limited time. It's not a fix. Take a toothbrush and some water or alcohol and run it over the pulley surfaces.Joe K.
'11 BMW 328i
'10 Matrix S AWD
I would suggest a Goodyear Gatorback belt. I have seen them fix every squeeky belt.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Whats goin on johnny?
Can't wait til I graduate and come back to check out that Z you picked up.
I suggest what everyone else said. Take the belt off, clean it thoroughly, and use brake or carb cleaner on the pulleys. Use a brush to get in to the grooves of the pulleys if you have to.
If that doesn't work, I'd try a new belt if the noise bothers you that much.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
That's the best belt made, and I agree it's very quiet.Originally posted by Jeff 95 Z28I would suggest a Goodyear Gatorback belt. I have seen them fix every squeeky belt.
