Perhaps Im just looking in the wrong places, but other than suspension stuff I havent been able to find any performance parts for a 3.4 engine. For the time being I'd like to do more of the cheaper and easier stuff first ie: headers, intake etc etc. Ive been thinking about a turbo, but that will have to wait until next tax refund. Thanks for any ideas.
3.4 V6 Performance Parts
LarryMow-93 V6 Firebird-No engine mods-Z06 Wheels, '98 Taillights,'98 Center Console-SLP fan switch-BMR STB, F/R Swaybars, PHB,LCA,Torque Arm, SFC, Bilsteins, Eibachs....www.cardomain.com/ride/2489691/1Tags: None
Not much out there. One possibility is a heads and intake manifold swap from a newer 3.1 liter V6, like the ones in W bodies.Tracy
Headers are available from RK sport, use a high flow cat and a decent cat back for a good flowing exhaust. Change the two piece driveshaft to a 1 piece 1LE aluminum shaft, swap the entire rear including brakes for a rear assembly from a LT1 stick shift car (3.42 ratio). Bypass the coolant passages in the throttle body, add a 160º thermostat, A cold air intake with decent filter, good state of tune with decent plugs and wires, you should have yourself a mid 15 second quarter mile V6 that still gives respectable mileage. Other than this stuff, anything else is going to be really scarce.
I've got a set of Z28 anti-sway bars if you want them.Tracy
