From what I am hearing from other members is that going with a turbo is the best way to go. Can we make it a Twin turbo ? Is that even better ?
Twin turbo for an LT1 is the best way to go ?
Good luck. It's going to cost you a ton of money. You can't just bolt two turbos on and call it a day. I'll let the others get into that though.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
SOLD- Good riddance!
TT would be better but its, as the guy above me said, not easy at all. Its alot more plumbing and alteration of parts and brackets and stuff like that its not easy to do unless you have alot of money to spend. Id still get a supercharger.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
1969 z28 - 9.957 @ 133.92 1.425 60 foot.
Yes, I also agree...and the temp under your hood would be rediculously high, unless you move stuff around well enough to keep cool air comming in. And as previous people have said, it wouldn't be easy, with our engine compartments being tight as they are.
BUT....if you can do it, my hat goes off to you!!! It would be pretty sweet to see a LT1-TT rollin' around the streets
Mike
1996 Pontiac Trans Am Ram Air: 160k kilometres, low temp T-stat, tuned, 3.73 gears, 3" Magnaflow exhaust, B&M skip shifter, BFG drag radials
I used to have a video of a twin turbo 97 Camaro SS. I think it was around 750 hp. Boy he lays waste to a lot of people.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
darkz711 -
Yes they do. www.ststurbo.comOriginally posted by Performin NormanI think STS makes a single rear mount system for LT1s.
Mike
Originally posted by darkz711
WOW!!!!!!!!!!! now thats looks like an every day driver that kills just about everything on the streets and u wouldnt know it by looking at it
current
383 LT1 with a Vortech S/C.... 9.04 @ 155mph, at a 4,000# race weight, and totally stock appearance, except for the NHRA mandatory 'chute and roll cage.
Slightly off topic unless the rear mounted turbo is a consideration. Isn't there a new NHRA rule that a turbo must be mounted under the hood?'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
