AC compressor
  • AC compressor
    I was just wandering if any body has taken out there AC compressor and swappe it with the 1LE delete pulley. What do i need to take out? I got the three bolts in the front and the belt so far????
    1995 Camaro Z28 auto
    Theres another mount in the back of the compressor with a bolt that goes to the block.
      do i need to take the radiator or the fan shroud out as well or should it just come right out?????
        After getting the mounting bolts out, the toughest part was the bolt holding the hoses to the back of the compressor. After that is removed, and the electical connection removed, it sorta falls out.
        I replaced the compressor, and the reverse proceedure was used, again, getting the bolt to hold the hoses was the toughest event.
          oh cool thank you
