I have also seen this on other TA's.
Driver's seatbelt always rubbing and making small rip in leather seat
If the seat belt is not being use ie: my passenger side, It does rub a bit and make a bit of noise against the leather seat. I don't know if thats what you are refering to. I'd like it to stay away from the seat myself.
Lava... how old are you and do you actually have a licence? I dont mean to be mean but its kindof rediculus how much you post, i meen i know you wanto learn more about your car and stuff but you need to space some things out a bit, and when u ask about turbos and stuff then ceramic breaks and then seatbelts i just dont c why u need to know alll of that right away in the same day. And by the way my seatbelt doesnt rub or make a rip.[COLOR=Navy]2000 Navy Blue Trans Am, T Tops, Automatic, Ram Air, Slp 85mm Mas, Air Lid, Smooth bellow, Hooker 1.75 Lt's, ORY, LM1, Air/EGR delete, Throttle body coolant bypass. Msd super conductor wires. TSP cam, ss3600, svo 38LB injectors.
1969 z28 - 9.957 @ 133.92 1.425 60 foot.
I love the depth, description and imagination that goes into this guy's posts lolOriginally posted by lavapearlI have also seen this on other TA's.
Mike
1996 Pontiac Trans Am Ram Air: 160k kilometres, low temp T-stat, tuned, 3.73 gears, 3" Magnaflow exhaust, B&M skip shifter, BFG drag radials
