I started installing all new valvetrain stuff, and it looks like I got the wrong valve seals. I am going to be using the stock valves. I looked up the GM part numbers and it looks like the intake and exhauxt valves are different. Any reccomendations?
I am installing:
CompCams #26918-16 Springs
CompCams #795-16 Steel Retainers
CompCams ##611-16 10 degree locks
CompCams #7940-16 HI_Tech Pushrod (5/16 7.200)
CompCams #850-16 CS O-E Hyd Roller Lifters
CraneCamss #10758-16 Aluminum Rocker Arm set (1.6 Ratio 3/8 stud Self Align)
I bought CompCams #506-16, but it looks like they are the wrong ones. What should I go with. Also, anything else I should be concerned with going with the parts I bought? Will the stock valve covers work?
BTW. I used the CraneCams #99473-1 Valve Spring compressor tool, and it was insanely simple to remove and install springs with the heads on the car. Expensive tool, but well worth it.
I am installing:
13.410 @ 102.66 11/20/05]
