OK so i am trying to get this pump off--I have removed the hoses, 5 bolts and a nut-It will not come off-is there anyhting else that i am missing? is that the air pump directly to the right of it?
water pump part dos
water pump part dos
Black '96 Z28, loudmouth exhaust, Mac mid length headers, crane cams powermax 104227 cam, crane 1.6rr,'s, springs, lifters and pushrods. MSD distributor, slp ultra z hood with air box, bbk 52mm throttle body, march underdrive pulleys, hpp+, 1le sway bars, spohn LCA's and relo brackets, Spohn SFC's, adj panhard bar, bilstein shocks, H&R springs, strut tower brace...Audio-Alpine head unit, MB Quart 6.5" component in the front and 6.5" Boston in the rear w Alpine 75x4 amp, Alpine Type-X 12 in the trunk w/ alpine 1000w ampTags: None
5 bolts and a stud hold the pump on.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
thanks--i found the brakcet and air pump i had to remove--only prob now is my dad--in a attempt to help cracked my optispark prying on the water pump--so much for a 1 day fixBlack '96 Z28, loudmouth exhaust, Mac mid length headers, crane cams powermax 104227 cam, crane 1.6rr,'s, springs, lifters and pushrods. MSD distributor, slp ultra z hood with air box, bbk 52mm throttle body, march underdrive pulleys, hpp+, 1le sway bars, spohn LCA's and relo brackets, Spohn SFC's, adj panhard bar, bilstein shocks, H&R springs, strut tower brace...Audio-Alpine head unit, MB Quart 6.5" component in the front and 6.5" Boston in the rear w Alpine 75x4 amp, Alpine Type-X 12 in the trunk w/ alpine 1000w amp
Oops. Dads can be dangerous. My father in law scares me. He will never touch my cars.Originally posted by fullthrottleZthanks--i found the brakcet and air pump i had to remove--only prob now is my dad--in a attempt to help cracked my optispark prying on the water pump--so much for a 1 day fix
Time for a new opti!Tracy
You can buy an opti in parts now instead of the whole thing. If the damage isn't that bad, you can save yourself some money.Originally posted by fullthrottleZthanks--i found the brakcet and air pump i had to remove--only prob now is my dad--in a attempt to help cracked my optispark prying on the water pump--so much for a 1 day fixHercules
2008 Sunburst Metallic HHR LT
well if you'ver never changed it, you might of been do.So best to get that out of the way when you already have your pump out. As for whether it's syill good or not, i think one crack on curtain parts of it will make your car skip, so i would even try. It would suck to do all that work and have it skip and need to take it all off again.1995 Camaro Z28 auto
