well i ordered o2 extensions from thunderracing and i guess i only ordered one of them, so once i get my headers in tommorow, will i be able to drive the car with only one of the sensors in???????????????????
only 1 o2 sensor extension!!!!!
okay thanks, but it won't run bad though??? and what does in loop mean??1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
He can just screw in the o2 sensor and leave it disconnected for the meantime. That bank will be in open loop obviously and it will cause the BLM's to be split. But it will run.
If it were me, I would wait to run the car until you get the other extension.
Originally posted by Kevin - Blown 95 TAIt's bad for the sensor to leave it disconnected from the wiring because of the heater being unpowered. It can get fouled up that way.
OK, but both my wideband kits recommend you not do that. So you can infer what you want to when it comes to 4 wire narrowband sensors. The heater is always powered up for a reason. They might be OK for a while, but who knows, especially when youre making mods to the car, and then running it in an untuned open loop.
But many cars, including the 93 LT1 use single-wire unheated O2 sensors. I have not heard that leaving the heater unconnected would cause fouling. The heater is there to bring it up to operating temperature and hold it there so it puts out the correct signal voltage.
Wide-bands may be different.Fred
