I just bought a 1985 Berlinetta 305 T-tops Been sitting in barn for 12 years. Good battery, small dose of fresh gas in carb, and she fired right up(with a little black smoke from the pipes but not at all bad) runs and idles good. I would like to put the Z body kit and a nice amount of horse power from a 350 (better than the 155hp 305) so i have tons of questions over the next few months or years depending how fast the wife lets me spend the money. Does that have a PC controlled tranny? If YES and I swap out the PC controlled carb and put a HEI distributor will my tranny still shift correct? And the digital speedo? I'm taking the interior apart now and then on to the body and when it's all done on to the drivetrain.
New F-Body owner, PC questions
I highly dobt that your tranny is computer contrlled. The new 4L60E was introduced in about 1995 or '94. My Firebird is a '95 and it has it.
In 1985 transmissions in GM cars were not PCM controlled. You will see it had what is called a TV cable. TV stands for Throttle Valve. It is a cable that goes from your throttle valve (carb) to the tranny. This way the tranny knows how much pressure to apply to the shiFt, based on throttle position.
I'm not sure if there were any vacuum modulated transmission in 1985 cars or not. If so, instead ot a TV cable there wil be a vacuum hose and the tranny will look at the available vacuum to determine engine load and shift firmness.Tracy
That kind of language is not allowed on this board!!!Originally posted by TraceZto apply to the "shit,"
haha... I'm sure you ment "shift"
sounded good though!
Ha ha ha. OOPS.Originally posted by SteveH95FormulaThat kind of language is not allowed on this board!!!
Whoopsie doopsie.
Correction made! You are right, it was supposed to say "shiFt" with an F in it!Tracy
That is correct. The digital dash works independantly of the computer. Just make sure you have the tach, oil and temp wires hooked up so it can get the signals it needs.Originally posted by metalicThanks, I know how the older tranny works but a guy told me he thought those was computer controlled. So if i change carb and distributor can i do away with the computer alltogether? Or does that have any control on my digital dash?
Yank the carb and distributor, replace them with non computerized ones and you are set to go. The only wires you'll need on the motor are the sensor wires I mentioned above for the gauges, a +ign wire on the coil and a charge lead from the alternator. If you use the stock alt, it may also require a +ign activation lead, and if you run an electric choke that will also require +ign.Tracy
