Misterious oil leak
  • Misterious oil leak
    an oil leak has started to come about on my Trans Am, I first thought it was the valve cover gasket but a through inspection revealed that it isn't that, it appears to be on the drivers side, an thoughts to where this could be coming from? I haven't had the chance to lift the car yet...
    1995 Pontiac Trans Am Formula
    Could always be the infamous LT1 intake manifold leak.
      Could also be the oil pressure sending unit, the oil filter itself, maybe even the intake but that's usually found on the passenger side rear corner. The EGR tends to cook the gasket material.
        I've located it....thanks it was the oil filter
