On my 1996 trans am, my driveshaft starts to vibrate around 80+ mph. Does anyone know why this might be happening? I'm sort of stumped so any help or feedback would be appreciated.
Common problem. There was a GM TSB to fix this, but it only covered the car when it was under warranty.
The solution is either a LS1 aluminum driveshaft or a 1LE aluminum driveshaft. You could also take your current driveshaft to a driveline shop and have them balance it.
Suggestion: Use the forum's "Search" feature for basic questions like this. This question has been answered many times.
1994 Z28 M6 Convertible Current Mods:
This has been reported on LT1 cars like said before, but the 3.73 gears have a reputation for exagerating it. Replacment driveshaft is usually the recommended solution.
Joe K.
'11 BMW 328i
'10 Matrix S AWD
Is there one that is recommended or the best one to go with? And what am I looking for in the driveshaft? A certain material (ie. aluminum), size, etc?
no they do not still make the 1LE dirveshaft. It has been discontinued. I'm having a hard time finding one myself and might just settle for an LS1 driveshaft since i dont plan on going to wild in the horsepower/torque category.
I've got the LS-1 driveshaft on my '95 firebird for $288.00 or so and the car felt a little smoother and lighter. Its a direct replacement to the LT1 DS.
You recently had the U-joint replaced and balanced, and NOW you have a vibration?!?! I would be back at that shop so fast, they would think I never left. What kind of work did they do for ya?
2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
Just got off the phone with the mechanic...he says the U-joint is all rusted to shit. Hopefully thats what the prob was.
Mike
Thta should be the first thing any mecanic looks for when diagnosing a vibration in the drive line. Ask to see the U-joint after they are done to see the wear and or rust. I would think if you have the drive shaft out and removed the u-joints to balance the shaft why not replace them right away? The mechanic should have suggested this. U-joints arent that expensive. Its like pulling a trany with 160,000 k, you might as well do the clutch while your there, cause you know you will have to do it right away anyways.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
