Hey guys can I just buy the OVC brackets and use any set of wires to go OVC or do the wires have to be made for that?
OVC Wires
You have to order a specific OTVC set or get a cut-to-fit set.
If you have stock exhaust manifolds, don't even think about it. You can be guaranteed you will roast the boots. They will work OK with aftermarket headers though.
I bought some used headers, theyre at Airborn right now, the guy gave me MSD 8.5mm wires and I thought they might work if I just bought the brackets, thanks for clearing it up!
Any recommendations on OVC wire sets?
ovc
thunderracing.com has a good set up..
I have the Taylor Spiro Pro 8.5 mm cut to fit. Pretty easy to put together if you lube them up good when putting the ends on.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
