I finally got the TA on the road today for the first time in months, and noticed something. When I start it and have it running in neutral, all is fine. Idles at around 800 RPM's. Drives fine from what I can see, pulls hard, no stumble. BUT, as I'm coming to a stop, and either push and hold the clutch in or have it in neutral as car is still rolling, the RPM's drop down to like 500, even 400 RPM's???? And it will stay down there until I've come to a complete stop for a couple of seconds. Then all of a sudden (as though the throttle was blipped) it jumps back to 800 RPM's and stays there per usual??? Wierd for sure. It doesn;t stall out or anything, but is annoying as hell. Because it doesn't happen all of the time (but very often) it's odd trying to launch with a varying RPM. Plus it's odd when it sounds like the car is off and has stalled, but really hasn't. I find I'm always staring at the dash now as I come to a stop...
Thanks for your help guys.
BTW, the TA is a 93, 6 speed, 161,000 km's, and runs fine otherwise.
Cheers,
Steve
Cheers,
Steve
SOLD: 1993 M6 Trans Am, black with ZR1 rims, Borla cat-back, Random Tech cat, SLP headers and Y, Morosso CAI
13.410 @ 102.66 11/20/05]
my bad, scratch the MAF idea. Just had one other thought, I've seen just plain bad (watered etc...) gas cause this kind of behavior also... might want to treat or re-fill the tank since it's been sitting a while.
Thanks guys! I'm going to try and diagnosis this problem this weekend. It's really wierd because it isn't happening all of the time. I'm sure everyone knows how annoying the "little things" can get. Thanks again and I'll keep you guys posted on what it was...
