Does anyone know the bolt size pattern of a 2000 trans am, and the offset min/max offset that will fit on my car.
rims specs
rims specs
1969 z28 - 9.957 @ 133.92 1.425 60 foot.Tags: None
Bolt circle is 5 x 4.75" or 5 x 120.65mm (not to be confused with the BMW 5 X 120mm).
Stock wheels are 16X8 55mm offset. WS6/SS wheels are 17x9 50mm offset.
What offset you need depends on what width wheel you are looking at. Safe offsets for 9.0" or 9.5" wide wheels are in the range of 45mm - 56mm. For the 10.0", 10.5" and 11.0" wide wheels, you want to keep it closer to 45mm - 50mm.
For drag wheels, you want to look at 15x8" 5.5" backspace or 15x10" 7.5" backspace.Fred
