What can I do to loss about 200 lbs. My car weight is 3480. I have a 95 Z28.
Car to heavy want to reduce weight
What have you done so far?
Here's a list of what everything weighs:
http://www.ls1tech.com/forums/archiv...p/t-17319.html
Decide what you can live without and go at it.... AC, ABS, tubular k-member and A-arms, light weight wheels and tires, rear seat and harnesses, light weight carpet, racing seats, etc.......Fred
There was a post from another forum posted on here that suggested folding the back seats down. You should look for that thread it was very helpful.1999 Ram Air Trans Am. M6
well a couple of things you could do is stop eating sweets...pops deffinately..step up your daily excersize plan a little bit..and pray..im just kidding, that was a joke..all of it..
but i know a couple things your could do to loose some weight..your car.....take out your back seats and back rest, you probably dont carry passengers in the back being there is no room..also, you could get a tubular k member that is much much lighter then the stock hunk of steel..and other stuff like that.. i myself am worried about that too, but not right now, im still tryin to figure out why my car wont start..damn thing
Originally posted by PonyriderWhat can I do to loss about 200 lbs. My car weight is 3480. I have a 95 Z28.-Jeff
My "deletes" list, and the car still weighs 3,635#
front bumper support
rear bumper support
hvac vacuum reservoir
front air bag sensor
horn #2
front sway bar and brackets
cruise control box and cable
AIR pump/lines
steering wheel (lightweight replacement)/drivers air bag
a/c compress/lines/condensor
radio/amp/speakers
cd player (aftermarket)
hatch cover panel
hatch carpet/liner
carpet insulation (partial)
T-top storage brackets
antenna - mast and cable
spare tire
jack
rear seats
rear seat harnesses
drivers harness (replaced with 5-point)
passenger harness (replaced with 5-point)
sun visors
catback - Mufflex
floor mats
EGR valve, solenoid, tube
EVAP canister, solenoid, lines
light weight drivers seat
brake dampers
exhaust heat shields
front license plate mount
composite hood/airbox
MAF sensor
Weld Pro-Stars
Moroso DS-2 front tires
aluminum shocks
Things that have added weight back in:
6-point roll bar (chrome moly)
TH400/Gear Vendor OD/cooler/Ultrabell/shield
Spohn HD rear sway bar
Spohn HD torque arm
3" chrome moly driveshaft
nitrous system - bottle/lines/solenoids
dual fuel pumps/braided lines/billet filter
second ECU/additional wiring and sensors
12-bolt
instruments
SFC's (chrome moly)
LCA relo brackets
shock tower brace
line lock
ZainoFred
