Hi Everyone,
We are hosting a GP on the KVR Cross Drilled or Slotted rotors. Both are the same price so please just make sure you specify on your order. We need at least 6 orders to make this GP possible. The GP will run until next Monday.
98-02 Front Cross Drilled or Slotted Rotors (pair): 196.99
98-02 Front Cross Drilled or Slotted Rotors with Cad Plating (pair): 216.99
98-02 Front & Rear Cross Drilled or Slotted Rotors (all 4): 389.99
98-02 Front & Rear Cross Drilled or Slotted Rotors (all 4): 429.99
98-02 KVR Front & Rear Carbon Fiber Metallic Brake Pads : 119.99
93-97 Front Cross Drilled or Slotted Rotors (pairRotors (pair): 134.99
93-97 Front Cross Drilled or Slotted Rotors with Cad Plating (pair): 154.99
93-97 KVR Front & Rear Carbon Fiber Metallic Brake Pads: 85.99
Right now these GP items are not listed on our web site. We will get something up tommorow. In the mean time, you can order with the regular part #'s and we will ensure you get the GP pricing if you put GP in the special comments section.
Cad plating is a cosmetic coating which helps protect the non pad contact surfaces of the rotors from premature rusting. It is available in black, gold or silver colors.
Thanks!
Thanks!
