First thing
2002 M6 LS1, Firehawk... engine and drivetrane is stock (except dyno tuning)
In August I plan on ordering some Kooks stainless steel LT's (best fit found for LS1's on 98's+) . All the people around me state that as they are stainless steel thus there is no need to get them coated (From a well respected guy who has built countless setups, latest is a NH 97 vette with a C5R motor on ls1tech)
Now I don't like the idea of introducing anything that will heat soak the engine harness and other electrical wiring as years down the road problems will develop. I beleive coated stainless LTs are the wise-est as they do not add any heat soak to the engine bay
so should I get them coated and if so with what?
The ceramic coating on my Poston's headers looks great, the coating on my SLP headers is discolored but still has perfect integrity. One thing in common..... a big reduction in radiant heat.
I found that in these tight engine bays, I only want to suffer once and ya never know when a not quite tight enough bolt will allow a gasket to burn though. Then you're at it all over again. At least with burn proof gaskets you can just retorque.
