Okay, my frined gave me two 12" punch 2 subs for free and there is nothing wrong with them, but after getting them hooked up..they won't work. I know it isn't the subs. Could it be the amp?? it is a brand new JBL, but it's a 4-channel, could that be why? or it might be the wiring, because only one sub willl work but the other one won't. can anyone help me please?????????????????????
problem with my subs..........
You're gonna have to be a little more specific. If I go off what little info you've given me, we're gonna be here for a while and I'll be typing a novel. I need to know how you have it wired, aka power, ground, RCA's or high level inputs, what wires from the subs are run to what locations at the amp, etc. I've been installing since I was 15, 7 of those as a professional, so I can help you. I just need more information."No, officer, that bottle is my onboard Halon system"
is the amp turning on? check your ground, check that you have power getting to the amp.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
hey never mind...........i found out what the probelm was1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
check your ground first, make sure its stable..and check if youre getting enough power to the amp with an Ohm meter..
Originally posted by RICEATER94BirdOkay, my frined gave me two 12" punch 2 subs for free and there is nothing wrong with them, but after getting them hooked up..they won't work. I know it isn't the subs. Could it be the amp?? it is a brand new JBL, but it's a 4-channel, could that be why? or it might be the wiring, because only one sub willl work but the other one won't. can anyone help me please?????????????????????-Jeff
