When my car idles and while driving there are rattling and hissing sounds but when I turn the A/C on the sounds stop. I believe that it comes from the front of the engine. I checked the belt and put belt dressing on to see if the hissing would stop but it wouldn’t. The sound is fairly loud; you can hear it from the inside of the car with the windows up. I hope I was able to describe this enough were someone can identify the problem. The car has 77k on it.
Help identify this sound: engine
My best guess would be the A/C clutch bearings are on the way out. I get that impression because when the a/c isn't on, the clutch freewheels on it's bearings. When the a/c is turned on, the clutch locks up and the assembly rotates on the compressor bearings. At least that's my best guess.......Originally posted by Zippo910When my car idles and while driving there are rattling and hissing sounds but when I turn the A/C on the sounds stop. I believe that it comes from the front of the engine. I checked the belt and put belt dressing on to see if the hissing would stop but it wouldn’t. The sound is fairly loud; you can hear it from the inside of the car with the windows up. I hope I was able to describe this enough were someone can identify the problem. The car has 77k on it.
you have to replace the clutch. To do so takes a special tool as well. It holds the center shaft still so that the clutch can be disassembled from the compressor.Originally posted by Zippo910Would I be able to replace just the clutch bearings or would I need to replace the whole thing?
thanks for the help.
Originally posted by Iceslim0I had a similar problem like this on my other firebird, and now have it on my new one. I actually just made a thread about it. Does it idle hard when the AC is on? It feels like the engine is stressed heavily.
The idle does change when I turn the A/C on but it’s not a sufficient change. I looked up your post, however I do not know what is causing your problem but I believe it is something different from mine; hopefully someone will be able to help you out.
97 Firebird, 3.8 5 spd
