what to buy with $100-$300???
  • #16
    yea i'm going to go with a tune, so who would you guys reccomend the tune from??? madz28???? and after i get the tune, i willl go with what was said about the LCA relocation. So does the LCA mean "lower control arm relocation" ? if so that seems like it would be hard work!!!
    1994 Pontiac Trans Am A4 Pacesetter Ceramic Coated Longtubes,3" ORY,Dual 3" Cutouts,No Cat,!AIR,!EGR,K&N CAI,Flowmaster Exhaust,Mad Z28 Tune,Spohn Subframe Connectors,Eibach Sportline Lowering Springs,KYB Shocks,17x9.5 Chrome ZO6 Rims,5% Tint
    • #17
      Spohn lower control arm (LCA), plus Spohn LCA relocation brackets. You can just barely see the stock LCA bolt for the axle end of the LCA at the top of the bracket, behind the sway bar. The relocation bracket lowers the axle end of the LCA a couple inches, by providing the two extra holes at the bottom of the bracket.
      • #18
        If you don't have traction issues, I would get a shift kit and a trans cooler. All these other things are great suggestions but if you like the idea of tire chirping 1-2 shifts then it is a killer bang for the buck mod.
        However on the same note if I was working paycheck to paycheck I'd stash the cash in the bank to deal with a nasty surprise, or take a look at maint items like brakes. 94's are going to have little things here and there that will hit you, and nothing sucks worse than having a car you can't drive because of a small repair bill.
        • #19
          how about LCA and LCA relocation and cutout for now
          2001 Trans Am WS6 M6
