This is complicated to put into a thread, but I figured I would give it a shot. I have an LT1 with GTP ported heads (new valves, springs etc. whatever his highest stage is, flowing almost 300cfm), ported intake, large TB, hooker longtubes with dual 3" going into mufflex y-pipe into carsound 3" high flow cats and then into single mufflex 4" exhuast the rest of the way out, Custom ground cam (similar to 306), 1.6R roller rockers etc. etc., Ed Wright custom programming for this setup, all the normal bolt ons like cold air etc.
I ran this motor 3 years ago and without much effort was in the 12's with 118-120 trap speeds prior to it letting a valve go. I finally got around to picking up another motor, had the heads re-done, and slapped it all together. After a couple mishaps (blown fuse that controls some sensors, bad water pump) the car runs without throwing any codes.
Symptoms are as follows. Pulls fine (as much as can be expected with this big of a cam at low RPM) up to about 3k, then trails off sharp power wise at 4500RPM and then it will rev up to 6-7k but lacks power. Sometimes Idle is good, sometimes it needs to be feathered to keep it running. Typically, it idles around 1200 which is where it is programmed to idle.
I am not getting any codes at the moment, no strange noises, almost all the components ran fine on the stock motor I slapped all this stuff into. It seems like it is acting like a timing issue or fuel ratio issue.
Any other tests I can run or any suggestions? My next steps are to do compression (was good on this bottom end with the stock heads) and check the plugs. Any help would be greatly apprecaited, I have spent a ton of time on this thing.
Thanks!
Eric
Thanks!
Eric
