Hello i havew a 1996 pontiac trans am or formula . I need to know where i can find the vehicle uvc code so i can figure out wich it is. As the vin numbers on the formulas and trans ams are the same. Any one know where they are located at on the 96 modle
uvc code as well as what my car is?
Not sure I know what a uvc code is, but RPO codes are in the glove box on earlier 4th gens and on the driver's door on later models.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Hmmm, I thought figuring out the difference between an TA and Formula would be quite easy. The front and rear fasica are different...not to mention TA had side skirts. In 1996 didn't all TA's have high rise spoilers? Unless it was a Formula and those parts were added on...
Post your VIN, and we'll tell you...
You can't tell from the VIN, as he already pointed out. The 5th digit in the VIN will be "V" = Formula/Trans Am.
You have to look at the RPO codes to verify what it left the factory as, assuming you can't tell from the bodywork.Fred
Ah, I wasn't thinking...I meant RPO codes. It's the weekend.Originally posted by InjuneerYou can't tell from the VIN, as he already pointed out. The 5th digit in the VIN will be "V" = Formula/Trans Am.
