Anybody ever degree a cam on an LT1? I just put my new Cam in, it has a 108degree centerline, the Cam went in at 105degrees so I used a bushing kit to get it to 108 degrees. My thoughts are this messed up the optispark timing (not revving very well) and this might be the symptom of my having degreed my cam.
Any thoughts?
So far, the results are as follows:
Craig at GTP says- Degree the Cam
Ed Wright programming says- put it in striaght up, it will impact timing, even though when they explained it, the computer still uses the knock sensor and O2 sensors to adust timing on the fly so you woudl think it would compensate
Going to ask the Cam guys now.....
Any thoughts?
Everything that has been discussed so far is right on the money. The big problem as you already know is the timing cannot be changed mechanically, it must be done via a new program. (except of course the change when the cam is retarded or advanced). My advice is to set the cam according to manufacturer specks and get a new program for the spark advance flashed. The cam timing is going to be important as it affects cylinder pressure, rpm power peak along with a few other things that cannot be "band-aided" by a simple timing change. This is why a dyno tune session is the best idea after a major internal swap.
