Hi I just bought 86 TA. Does anyone know where the hatch release button is?
rear hatch problem
Joe is right. The remote release was an option in '86.
If your TA has it the switch would be right below the gauges near the middle of the dash.
Options for getting in are limited.
Locksmith.
Go to a GM dealer and get a new key made. (taking your chances wasting your money on this one, since someone could have changed the lock)
Try crawling through from the front and pull the bottom of the trim up and pop it from inside. But you have to be very agile/small to even attempt this (I wouldn't even try it) I'm not even sure it can be done, there isn't much room to reach around the trim (besides I tend to get freaked out in small spaces).
Bruce, μολων λαβέ
I've done it and it's a PITA. Had to pop it with a screw driver.Originally posted by bru333
Try crawling through from the front and pull the bottom of the trim up and pop it from inside. But you have to be very agile/small to even attempt this (I wouldn't even try it) I'm not even sure it can be done, there isn't much room to reach around the trim.
it can be done but its a PITA1996 Trans Am WS6
A4, 3" VForce Catback, Corvette C6 rims, Slotted and Drilled Rotors, 160*stat, BMR SFC, HPP3, B&M Shift Kit.
