Hello all. This is my first post here on this forum. I have a 1993 Formula A4. Vehicle is very well kept. Been a mechanic for the past 9 years. but having a problem with an annoying noise at 2200-2400rpm, which i cannot figure out. I run an auto shop, and have unlimited access to all diagnostic tools except a scope. Now to the problem.
It makes this noise regardless driving down the road or sitting still and reving. Sounds like a harmonic noise, something how a worn out wheel bearing sounds at 60mph. Its not wheel bearings cause it also does this at a stand still with reving to 2200-2400rpm. Previous to this noise i had the motor mounts collapse, front of the motor nose dived into the sway bar, but not hard. After finding out I cannot buy them aftermarket and the dealer wanted $85 (wholesale) each, i installed energy suspension inserts and new ES trans mount. At that point i noticed this noise. At that point I found out that the 94 Impala used a similer center piece in their mount(aftermarket by Pioneer). Tried that. Same noise. Finally bought an OEM mount... Installed.. and SAME noise with slight variations between each. At the same time installing the mounts I removed the front half of the echaust and welded a new converter on(original was hollowed out by previous owner). Converter was exact size replacement, just a weld on unit.
Each time changing the mounts i checked around the engine looking for any contact with the body. All areas had atleast 1/2" to 3/4" minimum in between engine/trans and body. Also no signs of shiny metal from something hitting it.
Things checked today:
Checked with snap-on scanner found:
No Codes.(OBD1)
both O2's slow, the right side was worse(02's only 3 months old),
TPS read 0-100%, .8volts to 5volts. Should be OK.
Blocklearn was 113 on left bank and 111 on right bank. Which would show computer compensated lean for an overly rich condition..
Ignition wires are Taylor with MSD Sleeving. (12mo old) no arcing found.
Opti is Delco, replaced a few months ago. Roughly 8k on it.
NGK Dbl Plat plugs replaced with opti.
Known Mods:
Lingenfelter 58mm throttle body
Port matched intake
Flow master muffler with stock pipes
I was told motor was stock, but i beleive there is a cam installed, but mild.
Not sure if PCM was tuned. Prom chip has a Small yellow smiley face sticker on it. Not something i that GM would put on, but im not sure. Also i found knock sensor is not working. all wires are good. but does not respond.
All these mods have been on for about 2 years and never had a noise problem. Fuel mileage is roughly 17/25 on midgrade fuel.
Tomorrow i will be doing a power balance test, rechecking fuel pressure, and installing new delco dbl plat plugs. Also new replacement O2 sensors.
Sorry for the long post. Im just trying to get everything out at once. Has anyone had a similar problem? What else is left to check? Any offers to trade your prestine 98+ T/A or SS for my broken car will be accepted...
Thanks guys. Please help if you can.
Doug
No Codes.(OBD1)
Known Mods:
Port matched intake
Doug
