How can I empty my reserve out on my 94 v6 camaro? I have way to much colant in there and its boiling out of the top. The car continues to over heat at 260 (but not every drive). I think i've added to much colant thinking it was low in the radiator, it then go back over to the reserve. Needless to say I don't know what the heck is going on, and I'm lost. I have been dealing with this problem since I flushed the system and replaced the water pump and thermostat. Could it be I put to much in it? Some folks are saying its a blown head gasket.....wouldn't I see a drop in power or performance?
Reserve question
Originally posted by crazycooterHow can I empty my reserve out on my 94 v6 camaro? I have way to much colant in there and its boiling out of the top. The car continues to over heat at 260 (but not every drive). I think i've added to much colant thinking it was low in the radiator, it then go back over to the reserve. Needless to say I don't know what the heck is going on, and I'm lost. I have been dealing with this problem since I flushed the system and replaced the water pump and thermostat. Could it be I put to much in it? Some folks are saying its a blown head gasket.....wouldn't I see a drop in power or performance?
took it for a pressure test. just got back. they said they couldn't do it because there was alot of pressure on the hose. they said if I take the radioator off and bring it back they can clean it out. will that help any? oh yeah and it ran under 180 going there and back. this is racking my brains out!!!!
NAPA sells a kit for $50 that can detect carbon monoxide in the radiator fluid for detecting a head gasket leak or cracked head. It comes with a bottle with a rubber stopper on it and a fluid that you put in the bottle. When cold you take the radiator cap off put some of the liquid in the bottle. Stick the bottle where the radiator cap goes and fire it up. If the fluid changes colors you have a leak.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by crazycooterspoke to soon! boiling over again this morning after running under 180 the past few days. this is driving me nuts. Its just after is sits a day that it boils over any sugestions besides taking it to a shop? any more help would be great! Thanks2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
First check to see if the overflow system is working correctly. Joe explained how it works... when the radiator gets hot, and the coolant expands, the pressure opens the spring in the cap, and some coolant flows out of the radiator to the reservoir. When you shut the engine off, and the coolant cools down, the coolant contracts and the resuling vacuum opens a second spring on the cap, and the vacuum pulls the coolant up the hose from the reservoir, and into the radiator to keep it full and free from air.
If you have a hole in the tube that leads from the reservoir to the radiator fill neck, the vacuum sucks air into the radiator, and you have problems.
You could also have a problem if the spring in the cap or the seals in the cap are faulty. When they pressure tested the radiator, did they also pressure test the cap?Fred
