My poor Camaro....Okay, Its a 1988 Chevy Camaro, w/ a 350 5.7Lin place of the O.E.M. 305 5.0L. Its not the Vacum Lines, Injectors, Filter or Sensors. although the computer does throw codes for the TPS, O2, MAP/MAF sensors. The engine Idles @ 2500-3000rpms. On start up the engine will start normally & idle down to about 900-1000rpms, w/ no issues, then I hear a large "whosssssshh" sound as if air is being sucked in or out, & alot of it. As soon as that noise starts, the engine jumps the Idle up & will not come down unless the noise somehow randomly stops. The car has had a full tune-up, All new ignition, all new cooling & all new fuel system rebuilt & almost every sensor changed. Also is running w/ a FlowMaster Duel Outlet Exauhst system 3inch Cat.Back. I cannot find where this noise is comming from but it sounds like it comes from the back side of the engine (where it meets the firewall/windsheld) The car only runs @ a high idle when this noise starts, Could it be a bad intake gasket?? that is my last guess.
Please help!
-Charles
