SLP Headers, 1-3/4" Tuned/Long Tube 2001-02 LS1 Camaro/Firebird 15% off only 2 sets l
Headers, 1-3/4" Tuned/Long Tube 2001-02 LS1 Camaro/Firebird Widely copied but never equaled, SLP's Tuned-Length Long-Tube Headers employ our patent-pending tuned-length design to optimize exhaust scavenging for phenomenal power increases. Gains of up to 41 horsepower and 58 lb.-ft. of torque are possible, depending on your application! These headers are constructed from 409 stainless steel and feature 1-3/4" primary tubes flowing into a 3" 4-into-1 collector. They're fully compatible with all stock emissions-control equipment and use OEM flanges for a perfect fit and proper bolt retention. NOTES: Requires Installation Kit #30054. Automatic-transmission-equipped convertibles will also require Crossbrace Kit #30055. Not legal for use on pollution-controlled motor vehicles. SLP Tuned-Length Long-Tube F-Body Headers: · Reduce 1/4-mile ETs by up to 5 tenths of a second and increase trap speeds by as much as 5 mph. · Offer bolt-on installation. · Are compatible with all factory emissions equipment. · Feature .055" wall-thickness 409 stainless steel to ensure long life. · Are mandrel bent to maximize flow. · Use Jet-Hot's polished aluminum-ceramic thermal-barrier coating (interior and exterior surfaces) to keep heat in, exhaust velocity up, and under-hood temperatures down. · Are covered by our Performance Guarantee and Limited Lifetime Warranty.
In Stock
$722.95
Catalytic Converters, 1998-02 High-Flow (pair); use w/#30051, #30052, #30053 These catalytic converters were designed specifically for low flow restriction and small size. We recommend them for use with our tuned length long tube LS1 F-car headers (Part #30051, 30052, 30053). They are also perfect for creating custom catalytic exhaust systems. Sold as a set of 2.
In Stock Quantity:
$297.95
SLP Header-Installation Kit, 1998-02 LS1 Camaro/Firebird
Header-Installation Kit, 1998-02 LS1 Camaro/Firebird Make your header installation easier with SLP installation kits. These kits are complete with all gaskets, bolts, fire sleeves, clamps and brackets that are required for your specific application. Detailed installation instructions are included. Individual components are available separately. NOTE: Call for details on each item.
In Stock Quantity:
$98.95
__________________
Stealth Performance
2092 NW Aloclek Drive #501
Hillsboro, Oregon 97124
(503)531-9166
E-Mail:
sales@stealthperf.com
Super Hot Deals on Baer Brakes this Month
In Stock
$722.95
In Stock Quantity:
$297.95
In Stock Quantity:
$98.95
__________________
Stealth Performance
(503)531-9166
E-Mail:
