I havn't had a low coolant light come on since I filled it to the top where it overflows when cap is put on (which I didn't do in the past), but I'm thinking it might be a bad cap which is possible. I'll wait to see if my light comes on again first then check it out. What I dont understand is if that means I had air in the system in the past why didn't the car overheat?
Mysterious Antifreeze Leak
This topic is closed.
Originally posted by EquatorHeat00What I dont understand is if that means I had air in the system in the past why didn't the car overheat?
I believe the problem is fixed, and I was thinking the worst for months. (like headgasket-but wasnt getting the symptoms) The antifreeze in the reservor when I checked it actually went up when the car was hot today first time I checked that when the proper amount of coolant was in the radiator. It hasnt done that since last spring when I installed my 160 degree thermostat. I just needed to fill the radiator to the very top.That explains why I never overheated, and I guess air in the top of the radiator causes it to diminish somehow. (Joe) So happy now! This post can now die!
