Hi all,
I swapped in a 3.42 used 10-bolt this weekend, replacing my 2.73 factory setup. Come to realize after doing this that the right side of the car is now sitting crooked, driver's side seems maybe a tad high, but the passenger side is definitely a good inch or so low. Enough that it's noticeable. I used the gap from tire to wheel well as a reference.
After taking a looksee at things (springs, isolators and such) it looks to me like the passenger side axle tube has spun slightly in the housing.
The rear seems to be fine. There is no bearing noise, no indication of major impact damage, and just a very slight gear whine around 40-50, which I think is fairly common. I can pick up the whine when cruising but if the window is cracked or the top is down, there's no hearing it, so it is pretty faint, definitely livable.
Any recommendations on what I should do? For the short term I just picked up a couple coil spring boosters and popped them in the passenger spring. This leveled things right up and functionally life is ok for now.
But I am concerned that the tube might slip again, or maybe the diff is a time bomb at this point. I was thinking of having the tubes at least tack welded with a couple really small spots for insurance, but it sounds like this is somewhat contraversial and not easy to do, either.
It doesn't seem to be a very common problem, so any help would be appreciated.
Tks.
Tks.
