My camaro has never had a problem starting, but the other day I noticed white residue under the battery, on the metal, that looks like battery acid. There was no trace of acid on the terminals though. So I unbolted and removed the batt and discovered the ingenious design of the coolant tank - the battery sits on a "tray" of black plastic which actually serves as the TOP of the coolant tank, of which the tank part is underneath. Neat way of saving space in a crowded engine bay, eh?
Anyways, the coolant tank did not have the white on it. I removed it, and the painted metal under it was full of the white stuff on one side. I don't think it's coolant???? Well I know that baking soda is good for cleaning battery acid, so I used some on the white stuff and it removed it - along with the red paint
so I guess it must have been acid? I looked at the sides and bottom of the battery and do not see any leaks.
If the battery is leaking wouldn't that shorten the life of the battery? How can it be leaking if I cant see any acid on the battery case itself? On the metal inner fender it appears that there is a white "trail" running down and back as if it leaked while the car was in motion. or could it have been some coolant runoff? Has anyone else had a leaky Delco battery?
bruce
so I guess it must have been acid? I looked at the sides and bottom of the battery and do not see any leaks.If the battery is leaking wouldn't that shorten the life of the battery? How can it be leaking if I cant see any acid on the battery case itself? On the metal inner fender it appears that there is a white "trail" running down and back as if it leaked while the car was in motion. or could it have been some coolant runoff? Has anyone else had a leaky Delco battery?
bruce
