I see questions over and over again. You don't have to replace them. All you have to do is clean them. If you're mechically inclined to remove them, just get a needle from grandma's sewing kit and start scraping the inside of the sensor through the little bitty holes that you see at the tip of the sensor. Blow the carbon off with your lungs each time you scrap. Screw the O2 back on and it's a done deal. This goes for all cars. If you don't have a computer to earse the MIL or service engine light, then just disconnect the battey before you clean the O2 sensor and reconnect the battery after you've re-installed the O2. Wait a couple of seconds and light will come off.
This is of course if you don't have a bad catilytic converter, plus it's a dang good place to start if you do have a bad catilytic converter to find the problem with O2 codes.
