Hi Guys!
I have a 1997 Z28 and it pop's in the exhaust when idling. It don't pop in the intake.
It will do this from idle to 1900RPM's. It puff's a little black smoke every now and then when it pop's. It will miss a little at a red light but not when I pull out and give it gas.
It don't hesitate in the upper RPM's and has plenty of power.
It did have a water pump leak last year and I replaced the pump.
I have replaced plugs and wires, EGR Valve, Checked the Fuel Pressure keyon Engine off 47Psi Idling 39 to 40 Psi.
What do you think it could be Fuel injectors, opti, ignition coil, ICM, O2 Sensors?
No Check Engine Light!
I am Puzzled!?
Thanks Lee!
I am Puzzled!?
Thanks Lee!
,SLP~Shorty headers, LoudMouth, Air Foil, LineLocks. Catco Cat. Hypertech 160. TB Bypass. MSD~8.5mm. Walbro 255lph. FT MAF ends. LT4KM. BMR~Adj LCA's, Rear sway, Panhard rod. HAL QA1 rear shocks. Random Tech adj TQ arm. Nitto NT555R's. Covered in Zaino. 13.466@103.85 N/A.
13.410 @ 102.66 11/20/05]
