My 88 Camaro filler neck has a small lip near the cap that causes fuel to leak when the tank is filled. I tried replacing the cap, but a new cap will not screw on. I even got one from the dealer and had the same problem. My question is, can the filler neck be replaced without lowering the tank down? I have never done this and trying to see what I'm getting myself into. Appreciate your replies. Thanks!
Fuel Tank Filler Neck
Ok it's been almost 9 months and I still haven't gotten to this. Has anyone lowered a tank and could tell if the neck is part of the tank or can it be removed? Thanks for your replies in advance.1988 5.0 TBI Camaro 700R4 Transmission
2000 3.8 SFI Camaro 4L60E Transmission, K&N Air Filter, and Drill/Slotted Rotors all around.
I had a 199 3.1 V6 bird that I replaced the fuel pump. I had to lower the tank and remember the neck was removable.
I would go to the dealer and check out an exploded view to see if indeed the neck can be seperated from the tank.
