ok im runing a non intercooled paxton blower setup with a seemingly high air intake charge... im thinking of using the stcok washer resevoir and pump and tapping some sort of a nozzle about 6" before the throttle plates and injection a water/alcohol mixture via a nozzle of some sort what do you guys think o fthis... i believe this would be beneficial and CHEAP! i was thinking of a simple switch on my shifter to activate while racing... the only question i have is what pressure do you think the washer pump runs at and what type of nozzle should i use to tap into the aluminum supercharger intake elbow?
im using this page as a guide but i want to know if anyone has ever tried this before...... http://www.dawesdevices.com/water.html
