Well, as luck would have it, I think my compressor is on the way out. I'm still 'reassembling" the supsension on the car. Spent a few hours cleaning up the rust on the lower control arms to paint/prime, but noticed a bit of oil on the front of the motor. One is leaking from the seal around the timing cover...no big deal. Been weeping for a few years. Never enough to register a drop on the dipstick.
The other is new(er). Noticed some oil around the a/c compressor. At first I though maybe one of the lines was leaking. However, I'm pretty sure it's leaking out of the snout around the clutch and maybe from the body seals. Anyway, it still works fine (ice cold) but you know what they say, where oil is leaking, so too is gas. If not now, soon anyway.
My concern is that once the compressor tanks, it'll frag into the system and I'll be replacing more parts. I'm thinking in the spring, I should replace the compressor with a new/remanufactured one. I'm not positive, but I think replacing the accumulator may be warranted as the dessicant is probably spent.
What do you guys think? Anyone done this yet? Any preferences/brands to look for/avoid? Is a remanufactured one safe to use or should I go new?
I was thinking I can replace the old parts then take it to a shop for a pump down and refill.
