So, after a couple weeks of the headers being on, I'm in love. I love the sound and performance. But, the outside of the #3 tube is rubbing on the steering shaft. When everything is cold, there's a slight clearance between the tube and the shaft with the rounded side pointing toward the tube. After being warmed up though, it rubs on the round sides, but still clears the flat sides. I wanted to try and adjust the shaft some, but its as far down onto the rack that it will go. I've got an LS1 shaft I want to put in (also eliminates the rag joint), but am not sure it will clear completely either. Is there anything else I can do? Craig and I did install new ES mounts when we did the headers. Also, fastTA/ponyBoy/SanFranGuy/whatever-the-heck-he's-going-by-this-hour suggested shimming the motor mounts lol. Would this be a good idea? Thanks in advance.
Header and Steering Shaft clearance
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Tags: None
I am not holding my breath for my name to ever stay the same!
Hec, Ken can't even spell fastTA right!
lol no comment
But, does anyone know any other way give some extra clearance between the header and the steering shaft? What can I adjust?Steve
Mods
Mods
Mods
Ummmm, no hammer pleaseOriginally posted by Joe 1320Got a hammer?
How about a pic?
. I'll try and get a pic tomorrow.
Steve
Mods
Mods
Mods
I'm tellin ya....shim the k-member stand on one side and clamshell on the other. Or if you are too lazy to do thatOriginally posted by Z Ya LaterUmmmm, no hammer please
, there are shops that can make you a custom steering shaft.
Ugh, I really don't wanna mess with the motor mounts right now lol. Call me lazy..whatever lol
Ok, here's some pics...
I couldn't really get a better angle at this point without bringing the Z into the garage and jacking it up. But, you can still see where its rubbing.Steve
Mods
Mods
Mods
...?Originally posted by paxton350Dude, ive been having the same problem for about 3 years and it really hasnt affected anything...
Ok...but that doesn't mean I don't want to fix it if possible. I didn't pay all this money for the headers and misc. parts for this project just to have this problem.Steve
Mods
Mods
Mods
Ok but im just giving you some input... i mean ive had the same slight rubbing issue onto the manifold for about 3 seasons and like i said it hasnt affected anything... but if you want to spend all the time and effort to dremel it out and clearance it go right ahead im just letting you know my expirience with this problem 3 years down the line for you...
The first thing I told him to do was grind the rag joint couplers down. But does Stev-O listen?...........Nooooooooooooooo!Originally posted by Joe 1320Bah..... a slight grind with a dremel and it will be just fine. You may try shifting the base of the steering column, but that's a longshot.
I think he said it was rubbing pretty bad though. May need the motor shimmed.
Its not that bad, and its not near the rag joint. Its on the smallest area, only only rubs on the rounded areas, not the flat, thinner areas. So, maybe a 1/4" at most. I was looking at the column and it looked like it was sitting slightly toward the pass. side (not angled). So, there may be enough there to get it to clear.
Geez, you guys are ruthless to me lol j/k
Steve
Mods
Mods
Mods
