I can't figure out if I have a leak. I changed my thermostat (stock) and filled up the coolant with dexcool mix to the neck of the radiator and then the overflow tank. A day later, before driving and when it was cold, I opened the radiator cap and again, the level was down. I added more - not sure exactly how much - until the level was again at the neck.
As far as operation, it seems to be ok. the temp gauge warms up as normal and there is hot heat from the heater. I do not see any dripping inside the car, or under the car, and
of the parts are wet such as the water pump, hoses, or radiator. So there is no visible sign of a leak.
Why would the level be low? Where could it be going? Or is it normal for the level to contract like that?
of the parts are wet such as the water pump, hoses, or radiator. So there is no visible sign of a leak.Why would the level be low? Where could it be going? Or is it normal for the level to contract like that?
