anyone happen to know where the location is for the fuses? thank you
headlight motor fuse location?
sorry..
I see no location identified either..
I'd just have to trace the wiring from the headlight module ,,
they will be the two orange wires for the right and left..
the '91's show that they are circuit breakers..
they were fusible links before that and in '92 they went to a fuse..
If I still had the '91 I'd trace them out for ya..sorry..
hope this helps,
Matt
ok so the fuses are located underneath the steering wheel and to the right. aftre you remove the pad that covers the steering column its right there. you would almost never see it cuz it is pretty hidden. just though i would post this in case if anyone else has this problem1991 Pontiac Trans Am V8 305
that where i thought too ... but its the 93 and above models. i did find it. 2 15 amp fuses for the LH and RH headlight motor, horn relay, and alarm. as soon as you take off the pad thats under the steering wheel its there all the way to right . just really hard to see cuz everything is black with exception to the horn relay which was a eggshell grayish color. this is the location for 1990-1992 models in case anyone else needs it. Convienence center? not so convienent if you ask me...1991 Pontiac Trans Am V8 305
