in some of my earlier post i mentioned i had some idling problems, first did my plugs, then after taking out the throttle body and IAC module and cleaning them, i ended up with a too high rpm. Today i did some checking again and pure coincidentally my finger just bumped into a hose of the EVAP system with a big hole in it. (So big my index finger just fitted into that hole)
this hose conntects to the valve solenoid (block bleeding i guess), located at the driver side, just under the hose that is coming from that big brake drum. i guess some big butT rat just chewed this big hole is this hose, and that was causing the high hissing i always heard in the motor, but never found the cause of it. also maybe that foul smell i smelled after starting the motor. i replaced the hose, and my idling seems now perfect. starts, goes to 1200rpm, dropping sharp back to 900 rpm. i even noticed the motor block runs now stable at starting, no more vigourously shaking for some minutes.
thank you all for your inputs at my earlier posts.
